I wanted to use deviceCookie to identify custom info. As i understand from the documentation deviceCookie shall be sent as part of discoveryResponse, there after this will present in other requests like stateRefresh, Command, etc.,
However i do not see support in st-schema-nodejs for adding deviceCookie as part of discoveryResponse. Please refer properties supported currently in the below image
Hi, @prakash_m
I asked the engineering team about this and they mentioned that you can create an issue about “deviceCookie” being missing in the SDK’s repository and they’ll put it in their backlog to update the SDK with it.
