[ST Schema] - How to publish a new version of SmartThings Cloud Connector App
I want to publish a new version of the Schema Connector to integrate a third-party cloud-connected device with SmartThings.
Schema App is currently published.
I want to add another device and change the hosting url.
But when I try to edit it, it says ‘You cannot make changes to the app because this project is published’.
Also, when I try to click New request, the message ‘Cannot publish a project that has a device profile using the deprecated metadata service.’ is displayed.
Do I need to create a new project to modify the app?
If I need to create a new project, is there any way to make it available to users of my existing app when I publish the new project?
Tagging @nayelyz @erickv
Hey, @111199
Regarding the update on the registered URLs, you can apply this change through the SmartThings CLI. The following commands will be enough to update the references:
# collect the connector's info
smartthings schema <app_id> -j -o connector.json
# push update to API
smartthings schema:update <app_id> -i connector.json
And about the certification of your new device model, please send an email to build@smartthings.com to escalate and follow up on this request properly.
hi @erickv
I tried schema:update using SmartThings CLI as you said, but it doesn’t work because it’s currently published.
The error contents are as follows.
Error: Request failed with status code 403: {“requestId”:“0DB6D4D0-14B0-47
4F-A19B-26CD0C5C9EC6”,“error”:{“code”:“Forbidden”,“message”:“Updating
endpointApp not allowed for certified endpointApps”}}
@111199 hmm… really interesting
I’ll submit a report right away because if I recall correctly, a few weeks ago this was still possible… even for published connectors.
One last thing, how did you authenticate your ST CLI?
@erickv Thank you for caring me.
I triggered the built-in OAuth flow.
Can you try the update command again, but passing a personal access token instead? i.e.:
smartthings schema:update -i connector.json -t <personal_access_token>
Let me know if you get the same error.
@erickv i got the same error.
Error: Request failed with status code 403: {“requestId”:“419FE85A-810E-44
42-AFD2-2A5CA7E69617”,“error”:{“code”:“Forbidden”,“message”:“Updating
@111199 Thanks for taking the time to test this out.
I’ll share the outcome with our team right away!
I wonder how the results of this document ended.
We had to change the information on the cloud connector by relocating the server.
I saw a similar error.
“requestId”: “393EDB45-C4C4-49BF-9F22-B0EAC064671A”,
“error”: {
“code”: “Forbidden”,
“message”: “Updating cloud connector not allowed for certified cloud connectors”
We are looking for a document or an answer on how you solved this problem.
Hi, @shk,
Do you only need to change the URL for your Schema Connector?
If so, please send the following info to build@smartthings.com:
  • App ID. This is located in the Developer Workspace (eg. “viper_xxx…”)
  • Current URL
  • New URL
You are right to understand. We just need to change our Schema Connector URL/URI. I will organize the information and send you an email soon. Thank you for your reply.
