Any ideas? One of my 4 St zigbee presence sensors is showing away approximately every 15 minutes and then quickly showing back up. The dongle is close to hub and reports 60 percent battery.
Getting annoying every time it leaves and comes back and notifies my wife and me… Other than disabling notifications for this device.
Anyway…does “close to the hub” mean “close to the wifi router”? Wifi can intermittently cause interference with zigbee, causing the away/present/away/present pattern with each disconnect.
Try moving the presence sensor one room away and see if that helps.
(Mobile devices like key fobs are particularly prone to this because they don’t have permanent neighbors.)
Close to the ST hub, where I always keep my keys, nothing new, nothing changed. So it is really odd. Logging in the IDE shows it started at 8:01pm tonight and has been in and out for 2 hours.
Prior to 8pm it was 100% accurate with no false aways or heres.
Wonder if the sensor just is failing. What’s the warranty on these things? 1 year? Anyone had one replaced?
