Yah … Looking at the SmartDevice Type Handler code is definitely helpful when the specifications documentation is unclear on some particular detail, but, frankly, it is a huge shame that there aren’t just a few more comments in the code that would expand on the attribute value ranges and so on. It’s been suggested by multiple folks in the Developer Office Hours Conference Calls that “JavaDoc” style comments would be terrific (@Ben, @Jim, …).
Well, for now, the code implies:
- Acceleration is reported with
acceleration: active / inactive
- ThreeAxis (orientation) is reported with an [x,y,z] map named
threeAxis
For convenience pasted here:
metadata {
// Automatically generated. Make future change here.
definition (name: "SmartSense Multi", namespace: "smartthings", author: "SmartThings") {
capability "Three Axis"
capability "Contact Sensor"
capability "Acceleration Sensor"
capability "Signal Strength"
capability "Temperature Measurement"
capability "Sensor"
capability "Battery"
fingerprint profileId: "FC01", deviceId: "0139"
simulator {
status "open": "zone report :: type: 19 value: 0031"
status "closed": "zone report :: type: 19 value: 0030"
status "acceleration": "acceleration: 1, rssi: 0, lqi: 0"
status "no acceleration": "acceleration: 0, rssi: 0, lqi: 0"
for (int i = 10; i <= 50; i += 10) {
status "temp ${i}C": "contactState: 0, accelerationState: 0, temp: $i C, battery: 100, rssi: 100, lqi: 255"
// kinda hacky because it depends on how it is installed
status "x,y,z: 0,0,0": "x: 0, y: 0, z: 0, rssi: 100, lqi: 255"
status "x,y,z: 1000,0,0": "x: 1000, y: 0, z: 0, rssi: 100, lqi: 255"
status "x,y,z: 0,1000,0": "x: 0, y: 1000, z: 0, rssi: 100, lqi: 255"
status "x,y,z: 0,0,1000": "x: 0, y: 0, z: 1000, rssi: 100, lqi: 255"
preferences {
input description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter \"-5\". If 3 degrees too cold, enter \"+3\".", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempOffset", "number", title: "Temperature Offset", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
tiles {
standardTile("contact", "device.contact", width: 2, height: 2) {
state("open", label:'${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
state("closed", label:'${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
standardTile("acceleration", "device.acceleration") {
state("active", label:'${name}', icon:"st.motion.acceleration.active", backgroundColor:"#53a7c0")
state("inactive", label:'${name}', icon:"st.motion.acceleration.inactive", backgroundColor:"#ffffff")
valueTile("temperature", "device.temperature") {
state("temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("3axis", "device.threeAxis", decoration: "flat", wordWrap: false) {
state("threeAxis", label:'${currentValue}', unit:"", backgroundColor:"#ffffff")
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false) {
state "battery", label:'${currentValue}% battery', unit:""/*, backgroundColors:[
[value: 5, color: "#BC2323"],
[value: 10, color: "#D04E00"],
[value: 15, color: "#F1D801"],
[value: 16, color: "#FFFFFF"]
valueTile("lqi", "device.lqi", decoration: "flat", inactiveLabel: false) {
state "lqi", label:'${currentValue}% signal', unit:""
main(["contact", "acceleration", "temperature"])
details(["contact", "acceleration", "temperature", "3axis", "battery"/*, "lqi"*/])
def results
if (!isSupportedDescription(description) || zigbee.isZoneType19(description)) {
results = parseSingleMessage(description)
else if (description == 'updated') {
//TODO is there a better way to handle this like the other device types?
results = parseOtherMessage(description)
else {
results = parseMultiSensorMessage(description)
log.debug "Parse returned $results.descriptionText"
return results
private Map parseSingleMessage(description) {
def name = parseName(description)
def value = parseValue(description)
def linkText = getLinkText(device)
def descriptionText = parseDescriptionText(linkText, value, description)
def handlerName = value == 'open' ? 'opened' : value
def isStateChange = isStateChange(device, name, value)
def results = [
value: value,
unit: null,
linkText: linkText,
descriptionText: descriptionText,
handlerName: handlerName,
isStateChange: isStateChange,
displayed: displayed(description, isStateChange)
log.debug "Parse results for $device: $results"
results
//TODO this just to handle 'updated' for now - investigate better way to do this
private Map parseOtherMessage(description) {
def name = null
def value = description
def descriptionText = description
def handlerName = description
def results = [
value: value,
unit: null,
linkText: linkText,
results
private List parseMultiSensorMessage(description) {
def results = []
if (isAccelerationMessage(description)) {
results = parseAccelerationMessage(description)
else if (isContactMessage(description)) {
results = parseContactMessage(description)
else if (isRssiLqiMessage(description)) {
results = parseRssiLqiMessage(description)
else if (isOrientationMessage(description)) {
results = parseOrientationMessage(description)
results
private List parseAccelerationMessage(String description) {
def results = []
def parts = description.split(',')
parts.each { part ->
part = part.trim()
if (part.startsWith('acceleration:')) {
results << getAccelerationResult(part, description)
else if (part.startsWith('rssi:')) {
results << getRssiResult(part, description)
else if (part.startsWith('lqi:')) {
results << getLqiResult(part, description)
results
private List parseContactMessage(String description) {
def results = []
part = part.trim()
if (part.startsWith('contactState:')) {
results << getContactResult(part, description)
else if (part.startsWith('accelerationState:')) {
else if (part.startsWith('temp:')) {
results << getTempResult(part, description)
else if (part.startsWith('battery:')) {
results << getBatteryResult(part, description)
results
private List parseOrientationMessage(String description) {
def results = []
def xyzResults = [x: 0, y: 0, z: 0]
part = part.trim()
if (part.startsWith('x:')) {
def unsignedX = part.split(":")[1].trim().toInteger()
def signedX = unsignedX > 32767 ? unsignedX - 65536 : unsignedX
xyzResults.x = signedX
else if (part.startsWith('y:')) {
def unsignedY = part.split(":")[1].trim().toInteger()
def signedY = unsignedY > 32767 ? unsignedY - 65536 : unsignedY
xyzResults.y = signedY
else if (part.startsWith('z:')) {
def unsignedZ = part.split(":")[1].trim().toInteger()
def signedZ = unsignedZ > 32767 ? unsignedZ - 65536 : unsignedZ
xyzResults.z = signedZ
results << getXyzResult(xyzResults, description)
results
private List parseRssiLqiMessage(String description) {
def results = []
// "lastHopRssi: 91, lastHopLqi: 255, rssi: 91, lqi: 255"
part = part.trim()
if (part.startsWith('lastHopRssi:')) {
results << getRssiResult(part, description, true)
else if (part.startsWith('lastHopLqi:')) {
results << getLqiResult(part, description, true)
results
private getContactResult(part, description) {
def name = "contact"
def value = part.endsWith("1") ? "open" : "closed"
def descriptionText = "$linkText was $handlerName"
value: value,
unit: null,
linkText: linkText,
private getAccelerationResult(part, description) {
def name = "acceleration"
def value = part.endsWith("1") ? "active" : "inactive"
def descriptionText = "$linkText was $value"
value: value,
unit: null,
linkText: linkText,
handlerName: value,
private getTempResult(part, description) {
def name = "temperature"
def temperatureScale = getTemperatureScale()
def value = zigbee.parseSmartThingsTemperatureValue(part, "temp: ", temperatureScale)
if (tempOffset) {
def offset = tempOffset as int
def v = value as int
value = v + offset
def descriptionText = "$linkText was $value°$temperatureScale"
def isStateChange = isTemperatureStateChange(device, name, value.toString())
value: value,
unit: temperatureScale,
linkText: linkText,
handlerName: name,
private getXyzResult(results, description) {
def name = "threeAxis"
def value = "${results.x},${results.y},${results.z}"
value: value,
unit: null,
linkText: linkText,
handlerName: name,
displayed: false
private getBatteryResult(part, description) {
def batteryDivisor = description.split(",").find {it.split(":")[0].trim() == "batteryDivisor"} ? description.split(",").find {it.split(":")[0].trim() == "batteryDivisor"}.split(":")[1].trim() : null
def name = "battery"
def value = zigbee.parseSmartThingsBatteryValue(part, batteryDivisor)
def unit = "%"
def descriptionText = "$linkText Battery was ${value}${unit}"
value: value,
unit: unit,
linkText: linkText,
handlerName: name,
displayed: false
private getRssiResult(part, description, lastHop=false) {
def name = lastHop ? "lastHopRssi" : "rssi"
def valueString = part.split(":")[1].trim()
def value = (Integer.parseInt(valueString) - 128).toString()
def descriptionText = "$linkText was $value dBm"
if (lastHop) {
descriptionText += " on the last hop"
value: value,
unit: "dBm",
linkText: linkText,
handlerName: null,
displayed: false
* Use LQI (Link Quality Indicator) as a measure of signal strength. The values
* are 0 to 255 (0x00 to 0xFF) and higher values represent higher signal
* strength. Return as a percentage of 255.
* Note: To make the signal strength indicator more accurate, we could combine
* LQI with RSSI.
private getLqiResult(part, description, lastHop=false) {
def name = lastHop ? "lastHopLqi" : "lqi"
def percentageOf = 255
def value = Math.round((Integer.parseInt(valueString) / percentageOf * 100)).toString()
def unit = "%"
def descriptionText = "$linkText Signal (LQI) was: ${value}${unit}"
if (lastHop) {
value: value,
unit: unit,
linkText: linkText,
handlerName: null,
displayed: false
private Boolean isAccelerationMessage(String description) {
// "acceleration: 1, rssi: 91, lqi: 255"
description ==~ /acceleration:.*rssi:.*lqi:.*/
private Boolean isContactMessage(String description) {
// "contactState: 1, accelerationState: 0, temp: 14.4 C, battery: 28, rssi: 59, lqi: 255"
description ==~ /contactState:.*accelerationState:.*temp:.*battery:.*rssi:.*lqi:.*/
private Boolean isRssiLqiMessage(String description) {
description ==~ /lastHopRssi:.*lastHopLqi:.*rssi:.*lqi:.*/
private Boolean isOrientationMessage(String description) {
// "x: 0, y: 33, z: 1017, rssi: 102, lqi: 255"
description ==~ /x:.*y:.*z:.*rssi:.*lqi:.*/
private String parseName(String description) {
if (isSupportedDescription(description)) {
return "contact"
null
private String parseValue(String description) {
if (!isSupportedDescription(description)) {
return description
else if (zigbee.translateStatusZoneType19(description)) {
return "open"
else {
return "closed"
private parseDescriptionText(String linkText, String value, String description) {
return value
value ? "$linkText was ${value == 'open' ? 'opened' : value}" : ""
