Is the Device Handler source code available?
If so, it would be educational from a Developer perspective to see how the Tile is defined, and test a copy of the code with a few variations (including conversion to Metric Centigrade…).
Just a thought. I’m enjoying exploring the code…
Well! Indeed the code is in the Example List. I paste it here for your convenience. Perhaps a follow-up message from me will let you now if I managed to make the desired change: Though someone may beat me to it; I’m not racing.
metadata {
simulator {
status "open": "zone report :: type: 19 value: 0031"
status "closed": "zone report :: type: 19 value: 0030"
status "acceleration": "acceleration: 1, rssi: 0, lqi: 0"
status "no acceleration": "acceleration: 0, rssi: 0, lqi: 0"
for (int i = 10; i <= 50; i += 10) {
status "temp ${i}C": "contactState: 0, accelerationState: 0, temp: $i C, battery: 100, rssi: 100, lqi: 255"
// kinda hacky because it depends on how it is installed
status "x,y,z: 0,0,0": "x: 0, y: 0, z: 0, rssi: 100, lqi: 255"
status "x,y,z: 1000,0,0": "x: 1000, y: 0, z: 0, rssi: 100, lqi: 255"
status "x,y,z: 0,1000,0": "x: 0, y: 1000, z: 0, rssi: 100, lqi: 255"
status "x,y,z: 0,0,1000": "x: 0, y: 0, z: 1000, rssi: 100, lqi: 255"
tiles {
standardTile("contact", "device.contact", width: 2, height: 2) {
state("open", label:'${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
state("closed", label:'${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
standardTile("acceleration", "device.acceleration") {
state("active", label:'${name}', icon:"st.motion.acceleration.active", backgroundColor:"#53a7c0")
state("inactive", label:'${name}', icon:"st.motion.acceleration.inactive", backgroundColor:"#ffffff")
valueTile("temperature", "device.temperature") {
state("temperature", label:'${currentValue}°', unit:"F",
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("3axis", "device.threeAxis", decoration: "flat") {
state("threeAxis", label:'${currentValue}', unit:"", backgroundColor:"#ffffff")
main(["contact", "acceleration", "temperature"])
details(["contact", "acceleration", "temperature", "3axis"])
def results
if (!isSupportedDescription(description) || zigbee.isZoneType19(description)) {
results = parseSingleMessage(description)
else if (description == 'updated') {
//TODO is there a better way to handle this like the other device types?
results = parseOtherMessage(description)
else {
results = parseMultiSensorMessage(description)
log.debug "Parse returned $results.descriptionText"
return results
private Map parseSingleMessage(description) {
def name = parseName(description)
def value = parseValue(description)
def linkText = getLinkText(device)
def descriptionText = parseDescriptionText(linkText, value, description)
def handlerName = value == 'open' ? 'opened' : value
def isStateChange = isStateChange(device, name, value)
def results = [
value: value,
unit: null,
linkText: linkText,
descriptionText: descriptionText,
handlerName: handlerName,
isStateChange: isStateChange,
displayed: displayed(description, isStateChange)
log.debug "Parse results for $device: $results"
results
//TODO this just to handle 'updated' for now - investigate better way to do this
private Map parseOtherMessage(description) {
def name = null
def value = description
def descriptionText = description
def handlerName = description
def results = [
value: value,
unit: null,
linkText: linkText,
results
private List parseMultiSensorMessage(description) {
def results = []
if (isAccelerationMessage(description)) {
results = parseAccelerationMessage(description)
else if (isContactMessage(description)) {
results = parseContactMessage(description)
else if (isRssiLqiMessage(description)) {
results = parseRssiLqiMessage(description)
else if (isOrientationMessage(description)) {
results = parseOrientationMessage(description)
results
private List parseAccelerationMessage(String description) {
def results = []
def parts = description.split(',')
parts.each { part ->
part = part.trim()
if (part.startsWith('acceleration:')) {
results << getAccelerationResult(part, description)
else if (part.startsWith('rssi:')) {
results << getRssiResult(part, description)
else if (part.startsWith('lqi:')) {
results << getLqiResult(part, description)
results
private List parseContactMessage(String description) {
def results = []
part = part.trim()
if (part.startsWith('contactState:')) {
results << getContactResult(part, description)
else if (part.startsWith('accelerationState:')) {
else if (part.startsWith('temp:')) {
results << getTempResult(part, description)
else if (part.startsWith('battery:')) {
results << getBatteryResult(part, description)
results
private List parseOrientationMessage(String description) {
def results = []
def xyzResults = [x: 0, y: 0, z: 0]
part = part.trim()
if (part.startsWith('x:')) {
def unsignedX = part.split(":")[1].trim().toInteger()
def signedX = unsignedX > 32767 ? unsignedX - 65536 : unsignedX
xyzResults.x = signedX
else if (part.startsWith('y:')) {
def unsignedY = part.split(":")[1].trim().toInteger()
def signedY = unsignedY > 32767 ? unsignedY - 65536 : unsignedY
xyzResults.y = signedY
else if (part.startsWith('z:')) {
def unsignedZ = part.split(":")[1].trim().toInteger()
def signedZ = unsignedZ > 32767 ? unsignedZ - 65536 : unsignedZ
xyzResults.z = signedZ
results << getXyzResult(xyzResults, description)
results
private List parseRssiLqiMessage(String description) {
def results = []
// "lastHopRssi: 91, lastHopLqi: 255, rssi: 91, lqi: 255"
part = part.trim()
if (part.startsWith('lastHopRssi:')) {
results << getRssiResult(part, description, true)
else if (part.startsWith('lastHopLqi:')) {
results << getLqiResult(part, description, true)
results
private getContactResult(part, description) {
def name = "contact"
def value = part.endsWith("1") ? "open" : "closed"
def descriptionText = "$linkText was $handlerName"
value: value,
unit: null,
linkText: linkText,
private getAccelerationResult(part, description) {
def name = "acceleration"
def value = part.endsWith("1") ? "active" : "inactive"
def descriptionText = "$linkText was $value"
value: value,
unit: null,
linkText: linkText,
handlerName: value,
private getTempResult(part, description) {
def name = "temperature"
def value = zigbee.parseSmartThingsTemperatureValue(part, "temp: ")
def descriptionText = "$linkText was $value°F"
def isStateChange = isTemperatureStateChange(device, name, value)
value: value,
unit: "F",
linkText: linkText,
handlerName: name,
private getXyzResult(results, description) {
def name = "threeAxis"
def value = "${results.x},${results.y},${results.z}"
value: value,
unit: null,
linkText: linkText,
handlerName: name,
displayed: false
private getBatteryResult(part, description) {
def batteryDivisor = description.split(",").find {it.split(":")[0].trim() == "batteryDivisor"} ? description.split(",").find {it.split(":")[0].trim() == "batteryDivisor"}.split(":")[1].trim() : null
def name = "battery"
def value = zigbee.parseSmartThingsBatteryValue(part, batteryDivisor)
def unit = "%"
def descriptionText = "$linkText Battery was ${value}${unit}"
value: value,
unit: unit,
linkText: linkText,
handlerName: name,
displayed: false
private getRssiResult(part, description, lastHop=false) {
def name = lastHop ? "lastHopRssi" : "rssi"
def valueString = part.split(":")[1].trim()
def value = (Integer.parseInt(valueString) - 128).toString()
def descriptionText = "$linkText was $value dBm"
if (lastHop) {
descriptionText += " on the last hop"
value: value,
unit: "dBm",
linkText: linkText,
handlerName: null,
displayed: false
* Use LQI (Link Quality Indicator) as a measure of signal strength. The values
* are 0 to 255 (0x00 to 0xFF) and higher values represent higher signal
* strength. Return as a percentage of 255.
* Note: To make the signal strength indicator more accurate, we could combine
* LQI with RSSI.
private getLqiResult(part, description, lastHop=false) {
def name = lastHop ? "lastHopLqi" : "lqi"
def percentageOf = 255
def value = Math.round((Integer.parseInt(valueString) / percentageOf * 100)).toString()
def unit = "%"
def descriptionText = "$linkText Signal (LQI) was: ${value}${unit}"
if (lastHop) {
value: value,
unit: unit,
linkText: linkText,
handlerName: null,
displayed: false
private Boolean isAccelerationMessage(String description) {
// "acceleration: 1, rssi: 91, lqi: 255"
description ==~ /acceleration:.*rssi:.*lqi:.*/
private Boolean isContactMessage(String description) {
// "contactState: 1, accelerationState: 0, temp: 14.4 C, battery: 28, rssi: 59, lqi: 255"
description ==~ /contactState:.*accelerationState:.*temp:.*battery:.*rssi:.*lqi:.*/
private Boolean isRssiLqiMessage(String description) {
description ==~ /lastHopRssi:.*lastHopLqi:.*rssi:.*lqi:.*/
private Boolean isOrientationMessage(String description) {
// "x: 0, y: 33, z: 1017, rssi: 102, lqi: 255"
description ==~ /x:.*y:.*z:.*rssi:.*lqi:.*/
private String parseName(String description) {
if (isSupportedDescription(description)) {
return "contact"
null
private String parseValue(String description) {
if (!isSupportedDescription(description)) {
return description
else if (zigbee.translateStatusZoneType19(description)) {
return "open"
else {
return "closed"
private parseDescriptionText(String linkText, String value, String description) {
return value
value ? "$linkText was ${value == 'open' ? 'opened' : value}" : ""
…CP.
