Cory_Booth
(Cory Booth)
December 15, 2022, 9:10pm
1
Long ago, using a post similar to this one:
Connected Smoke Alarms - Devices & Integrations / Connected Things - SmartThings Community
I connected my wired Smoke Alarms via a relay to an Ecolink Open/Close Sensor.
If I recall, I was able to replicate a “Smoke Alarm” in the UI by changing the default settings from “open/closed” to “smoke/clear” in the generic DHT
Anyone working on something like this - it would seem to be super simple to deploy.
Zwave Masquerade will do that.
This driver allows simple z-wave devices, such as switches and binary sensors, to act as a different type of device. A typical use would be to make a z-wave contact sensor appear in the SmartThings app as a smoke detector.
Profiles are included for:
Acceleration sensors
Alarms
Carbon monoxide detectors
Contact sensors
Leak sensors
Locks
Motion sensors
Presence
Smoke detectors
Switches
Tamper alerts
Temperature alarms
Water level sensor (custom capability with low/normal/high states)
Water valves
Window shades
Use the settings menu to swap between profiles (you may need to close and reopen the app to see the new profile). A setting is also available to invert the reported status.
To use, enroll using the Channel Invitation and install the driver (choose the latest version if multiple a…
