[LAN Driver] SolarEdge Inverter via local Modbus TCP (SunSpec)
Reads live power, lifetime energy, DC voltage/power, temperature, and operating status from a SolarEdge inverter over its local Modbus TCP interface — no cloud dependency, no SolarEdge API key or monitoring-portal rate limits. If you have a SolarEdge production/consumption meter attached (e.g. the SE-RGMTR series), it also reads live net grid power (import vs. export) and lifetime exported/imported energy as a separate “Grid” component — read-only, detected automatically at startup, no config needed.
Channel invite: SmartThings. Add a little smartness to your things.
GitHub:smartthings-drivers/se-modbus-driver at main · ST-SmartHome/smartthings-drivers · GitHub
Tested against an SE5000AU (single-phase, SunSpec Model 101). Should work on any SolarEdge inverter with Modbus TCP enabled and reachable on your LAN — SunSpec’s inverter model (101/single-phase, 102/split-phase, 103/three-phase) shares the same register layout, and the driver locates it dynamically rather than assuming a fixed address (see “Notes for other models” below).
Requirements
- SolarEdge inverter with Modbus TCP enabled (on the inverter: Communication
→ LAN Conf → Modbus TCP). Disabled by default. - Known LAN IP of the inverter, and its Modbus TCP port (usually 502, some units/firmware use 1502 — check yours).
- A SmartThings Hub (this is a Hub-local LAN Edge Driver, not cloud-connected).
Setup
- Accept the channel invite above and enroll your hub.
- Install the driver (“SE Modbus” or similar) from the channel onto your hub.
- In the SmartThings app: Add Device → Scan Nearby. It should offer a generic “SolarEdge Inverter” device immediately — this driver doesn’t wait on any network broadcast (see why, below), so there’s no scan delay.
- Add it, then open its device settings and fill in your inverter’s IP, Modbus port, and unit ID (SolarEdge’s default unit ID is
1). Save. - Polling starts automatically on save, on the interval you set (default 30s).
Why this exists / what’s different from a “normal” LAN driver
Most SmartThings LAN drivers use search-parameters.yml to gate discovery on SSDP or mDNS traffic — the hub only bothers running your driver’s discovery code when it sees a matching network broadcast, which saves resources. SolarEdge’s Modbus TCP service never broadcasts anything — per SolarEdge’s own docs, it’s a passive server that “does not initiate a connection… waits for a client to connect.” A driver gated on SSDP for a device like this will never be invoked — confirmed the hard way, via a live logcat capture during an actual “Add Device” attempt that produced zero log lines.
This driver doesn’t use search-parameters.yml at all. Discovery unconditionally offers one device when triggered, and you supply the real IP as a device preference afterward. If you’re adapting this pattern for another self-announcing-nothing LAN device, that’s the part worth copying.
(Worth being precise about why stock drivers gate on SSDP/mDNS in the first place, credit to a community reply for the correction: it’s because they’re installed automatically on every single hub, so without gating, every hub would offer to create devices for protocols the user might not even own hardware for. A community driver is opt-in — you only install it if you already know you have the device — so that particular problem doesn’t apply here, and unconditional discovery is the simpler, correct choice rather than a compromise standing in for the “real” pattern.)
Notes for other SolarEdge models / three-phase units
- The driver walks the SunSpec model chain (reads the
SunSidentifier, then follows the model header chain) to find the Inverter model (101/102/103) rather than assuming a fixed register address — this varies by device/firmware, don’t hardcode it. - SunSpec defines four temperature slots (Cabinet/Sink/Transformer/Other); vendors typically populate only one, leaving the rest at the “not implemented” sentinel value. This driver reads all four and uses whichever one actually has data — on the SE5000AU tested, that’s the Heat Sink slot, not Cabinet.
- On the inverter side, only reads total AC power, lifetime energy, DC voltage/power, temperature, and status — doesn’t currently read per-phase voltage/current (relevant mainly for three-phase units). Would be a straightforward addition using the same model-relative offset pattern in
src/solaredge.luaif anyone wants it. (The optional grid meter, below, is a separate thing and already implemented.)
Grid meter
If a SunSpec meter model (201/202/203/204) is found in the Modbus chain right after the inverter model, the driver reads it in the same Modbus session (see “known limitations” below on why) and exposes it as a second “Grid” component:
- Power meter: net grid power in watts, signed — negative means importing from the grid (consuming), positive means exporting (selling back). Confirmed against a live overnight reading (inverter asleep, 0W production) showing a negative value matching real household draw.
- Grid Energy: lifetime exported and imported totals in kWh, as two separate read-only values (a custom capability — SmartThings has no standard capability for this).
No meter, no component — this degrades cleanly, it’s not a hard requirement.
Known limitations
- SolarEdge inverters accept one Modbus TCP connection at a time — if you already have something else (Home Assistant, etc.) polling the same inverter, this driver’s connection attempts will conflict with it. This is also why the grid meter is read in the same connection as the inverter data rather than a second one.
- Operating status (OFF/SLEEPING/STARTING/MPPT/THROTTLED/SHUTTING_DOWN/FAULT/STANDBY) is exposed as a free-text custom capability (“Inverter Status”) rather than a strict enum — there’s no great standard capability fit for inverter operating state, and SmartThings doesn’t support custom enum-typed attributes as cleanly as free text.
