[RELEASE] Edge Driver for Solar Inverters (AISWEI, Zeversolar, Auxsol, SolPlanet,...)
Hi everyone,
I'd like to share a new Edge driver I developed for local integration of solar inverters. This driver has been tested and is compatible with several brands that use the same HTTP communication protocol.
Compatible Devices
The driver should work with inverters from:
  • AISWEI (ASW Series)
  • Zeversolar
  • Auxsol
  • SolPlanet
Basically, if your inverter returns JSON data via a URL in the format below, this driver should work for you.
Technical Requirement (URL Format)
The driver queries the inverter by accessing the following URL:
http://<INVERTER_IP>:<PORT>/getdevdata.cgi?device=<ID>&sn=<SERIAL_NUMBER>
Make sure your inverter responds to this call with a JSON containing generation data (such as pac, eto, tmp, etc.).
Features
The driver monitors and reports the following information in SmartThings:
  • Current Power (W) - Updated every 10 seconds
  • Total Energy (kWh)
  • Inverter Temperature (°C)
  • AC Voltage (V)
  • AC Current (A)
  • Online/Offline Status
How to Install and Configure
  1. Subscribe to the channel (invite link) and install the Solar Inverter driver.
  2. In the SmartThings app, go to "Add device" and choose "Scan for nearby devices".
  3. A "Solar Inverter" device will be created.
  4. Open the device, go to Settings (three dots in top right corner > Settings) and fill in:
    • Device IP: The local IP address of the inverter.
    • Device Port: The communication port (Usually 8484).
    • Device SN: The inverter's serial number.
    • Device ID: The device ID (Usually 2, but may vary).
I hope this is useful! Any feedback or issues, please comment below.
Great Patrick! Congratulations!
I installed your other drive for Shelly 3EM Pro, but when I try to add it by “Scan for nearby devices”, it does not include at Smartthings. Is there something more to do?
Thanks a lot
Olá Patrick! Meus Parabéns!
Eu instalei seu outro driver do Shelly Pro 3EM, mas na hora de buscar pelo dispositivo dentro do Smartthings, ele não encontra. É necessário fazer algo a mais?
Muito Obrigado.
Qual foi a empresa que instalou as placas e o inversor na sua casa, precisando de indicação para orçamento… É homologado pela CEMIG? Pode se usar os créditos em outra residência do mesmo CPF…
Try again, now its corrects. I changed the name driver.
I bought in Aldo Solar.
Worked Patrick!
Thanks a lot!
Funcionou!
Muito obrigado Patrick!
Just looking at this and I was wondering if there was any way to get this working for Growatt inverters?
Também estou precisando.
Great driver… to make it more flexible you can modify the settings to personalize and add other information containing generation data in device 2, 3 or 4 Solplanet inverter, like battery information “soc”, pannel power “ppv” etc…
