[ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver
@paulonthenet
Yes, this helps, thank you.
Seems pretty simple. Will update when done
@paulonthenet
I added the fingerprint of your device and a basic handling. However, I don’t have this device, so unable to test it.
Please let me know if it works for you.
Regards
The driver version 2022-05-26T21:03:28.264597290Z
I fortunately don’t have the device. I’ve been thinking about buying one but there is no driver so haven’t bought one yet. It is this one.
Works great and nice to see the signal strength information.
Thank you for adding this, Im sure there will be quite a lot of people using this cheap Tuya sensor who will benefit.
@Sakari
Aqara uses proprietary messaging format. Without the device to test against it it would be very challenging to add support for it. I’m sorry, I won’t be able to help here.
However, there is device handler for it that might work
There are also community members that develop edge drivers for Aqara devices, perhaps they can help. @veonua @erickv @Mariano_Colmenarejo and others.
Cheers
Thanks. Maybe I just buy one and see if some one can help me.
@Sakari
Please be prepared to provide logs from smarthings cli. If something doesn’t work, it is the only way to see what’s happening with edge driver
Yep, no problem. I’m familiar with CLI.
Hi Yakov,
I have connected 2 of my 4 Tuya sensors using your driver and they are working correctly but I have 2 others that wont connect.
The only difference between them seems to be that the one you wrote the driver for is on application 4A and the ones I have that wont connect are on application 00
See attached.
Can this be easily added?
@paulonthenet
The manufacturer is different, hence the driver does not recognise the device.
However, it looks very similar. I will add the new fingerprint and we will see how it goes
@paulonthenet
I added the TUYATEC-v3uxbuxy/RH3052 fingerprint to the driver.
Regards
The driver version is 2022-05-27T19:20:47.838285380Z
It should be already installed on your hub by now
Thank you, the sensors are now connected and working :+1:
Hi all,
I added the ability to select what is shown on a dashboard tile for Temperature and Humidity Sensors as requested in
Regards
I dont know if its a sensor problem or a driver problem but one of my TUYATEC-v3uxbuxy/RH3052 is showing 7% battery with either the old or a new battery. I’ve tried deleting and re-adding the sensor but always shows 7% battery.
Any thoughts?
@paulonthenet
Could you please collect logs for the one that shows 7% and any other that seems to be working?
@ygerlovin Is it possible to add Aqara FP1 presence sensor please?
Hi @Steve_Mason ,
I really have no idea. New Aqara devices require special pairing that ST does not support.
See Supporting new E1 Aqara devices
Does the lighting sensor work in automations in the RTCGQ11LM? (the detections work but do not activate the automations in my case). thanks e Cheers
Hi @domenico_antonio_puo
It should be working.
What automation are you trying to create?
Are you on Android?
i am on IOS, my automation is: turn on light if aqara sensor detects lux less than 200.
