I think you have an edge driver that controls those devices.
You can validate it by checking driver used for those devices.
What you describe is exactly how devices, created with edge drivers are currently shown in IDE
I am new to the topic and I did not understand correctly, thatâs why I added screenshots how it looks for me.
The first screenshot shows what it looks like after importing from github, the other two how it looks like on HUB.
I will be grateful for your help.
It sounds to me like you have installed an Edge driver for the Aqara sensors, for example the one this thread is discussing. You would have followed an invitation link to a web page and clicked on buttons to enrol your hub with a channel, look for available drivers, and install them to your hub. If you look at the devices in the mobile app and click on their settings you will see an extra âDriversâ menu.
The IDE is a tool for working with the remnants of the legacy platform, so basically Groovy Device Handlers and SmartApps. Unfortunately it still gets used rather a lot when not working with said remnants. Modern integrations like Edge drivers just appear as devices using âplaceholderâ device types in the IDE and show very little in the way of other detail because the IDE doesnât need to know about it.
Iâve lost track of the priorities of the various integrations. I thought that priority went to custom DTHs, then Edge drivers, and lastly stock DTHs, but that might only apply if all is otherwise equal with the fingerprints. As Edge drivers can cover a range of different devices, usually with something in common such as manufacturer or type, installing just one driver can have a big effect.
Maybe I have too many drivers added, I have the ones from github and two kinds of edge from the forum. For devices that are correctly added, I can change the driver in the application (see screenshot below), but for those âplaceholdersâ I do not have such an option (see screenshot below), for those I cannot add them to the HUB via WWW and the application is visible but when I try to add them via WWW I have this message: Access Denied
Weâre sorry, but you are not authorized to perform the requested operation.
Hi, not working MCCGQ01LM.
Could you please elaborate whatâs not working?
Would it be possible to provide the logs?
Not pairing((
Aqara MCCGQ11LM, work well
It is known issue for Xiaomi sensors.
It may take several attempts to successfully pair them.
Could you please describe the pairing process you are doing?
@psix.anp Also, try the following procedure (strangely enough, I couldnât find my original post that is referenced below)
@psix.anp
Ok, found it.
It was for different device, but with Xiaomi the idea is the same.
1.Put the hub into paring mode
2. Long press a button on device until is starts blinking
3. Release the button, wait for device to stop nlinking
4. Short press button with the same time interval to prevent device going into sleeping mode
Note the led, press button only if the led is off
Uraaah, work fine
Just a side note, consider removing the ones you donât use.
I saw some reports of unavailability due to the number of installed drivers.
Hub has limited resources for storaging and processing.
Do any of you use channel 25 for zigbee? I read that some old devices struggle to use 25 so I was wondering if the aqara port sensors work with this channel, because I can not associate them.
Edit: Port sensor and Aqara motion sensor with difficulty, but they are connected to the hub on channel 25.
I point this out because a migration guide said that the new aeotec hub is set by default on channel 25, but they said that not all old devices are compatible with this channel.
Iâm using channel 19 and donât have a problem with my Aqara devices.
Hi,
Driver v1.2 was released
Timestamp: 2022-03-05T12:34:17.571490Z
Change log:
1. Add support for Tuya Temperature Humidity sensor QWS-001
Cheers,
Yakov
Is it possible to add the non LCD display version of the Tuya Temperature & Humidity sensor to this driver?
Does anyone have Aqara vibration sensor in use? Could it be added to this driver?
