Mi motion sensor (RTCGQ01LM) - connect to smarthings
Hello, my smarthings hub V 3 does not find them. In the supported devices do not see Mi or Xiaomi. I have lots of aquara and all works fine. What is needed / any way to connect them to Smartthings? Thanks Hans
Install this driver:
Click here:
https://bestow-regional.api.smartthings.com/invite/8b2Ay0rKX2ve
Log in, accept, enroll, available drivers, install driver.
Hello Andreas, thanks for the fast reply. These great edge drivers I already have installed for some time. Tried to find the devices with near you search, using the aqara different motion sensors. But they do not show up / connect. Thanks
Try the Zigbee Motion Sensor Mc from here:
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
And if this doesn’t work, we’d have to find out the devices fingerprint…
Maybe these instructions can help you
Hello Andreas,
thanks. I tried and tried again with the initial edge driver and now the MI Motion sensor devices connected. Took several tries but finally all three new MI motion sensors connected.
One issue I have with a different device. Aquara.Rocker switch
The rocker switch with two buttons connects and stays connected. (works really great). The single rocker connects. 2-3 days all fine. But then stops to function and / or disconnects from the network. (Signal strenght should not be issue, as next to it a Motions Sensor which works fine and single rockers are the only devices disconnecting in my network). Thanks for any idea! Hans
Do you have any Zigbee routers/repeaters (mains powered, not battery powered devices) in your network? A Zigbee smart plug, for example, in every room can greatly enhance the mesh network.
