Hi,
I’ve recently acquired one of the new Sonos Beam Soundbars. While the device as such is great I’m unhappy because it is not working well with ST. Is anybody else having any issues?
Device discovery worked well but controlling it is very unreliable. No matter if I use the controls in the “Thing” or a Speaker Companion app the commands goes through only occasionally. Most times the device does not respond, however, sometimes it does and I cannot recognize a pattern.
Here are some live loggings on failed attempts to start a track. Can anybody provide help or input what’s going on? Any help would be greatly appreciated.
I’ve e-mailed support but they said the Sonos Beam is not on the supported device list. But I would expect Sonos to use the same API on all their devices, right?
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:56 AM: trace sonosAction(Play, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:56 AM: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:x-sonosapi-stream:s80469?sid=254&flags=8224&sn=0, CurrentURIMetaData:dc:titleR.SA Live</dc:title>upnp:classobject.item.audioItem.audioBroadcast</upnp:class>SA_RINCON65031_])
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:56 AM: info setTrack(x-sonosapi-stream:s80469?sid=254&flags=8224&sn=0, null, 468 B})
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:56 AM: trace setTrack(x-sonosapi-stream:s80469?sid=254&flags=8224&sn=0, 468 B)
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:56 AM: trace playTrack(Map)
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:37 AM: trace sonosAction(Play, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, Speed:1])
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:37 AM: trace sonosAction(SetAVTransportURI, AVTransport, /MediaRenderer/AVTransport/Control, [InstanceID:0, CurrentURI:x-sonosapi-stream:s228215?sid=254&flags=8224&sn=0, CurrentURIMetaData:dc:titleSLEEP RADIO</dc:title>upnp:classobject.item.audioItem.audioBroadcast</upnp:class>SA_RINCON65031_])
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:37 AM: info setTrack(x-sonosapi-stream:s228215?sid=254&flags=8224&sn=0, null, 470 B})
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:37 AM: trace setTrack(x-sonosapi-stream:s228215?sid=254&flags=8224&sn=0, 470 B)
4b5cd19e-9772-413c-bec2-28be6fd9534b 6:57:37 AM: trace playTrack(Map)
