danielccm
(Daniel Consuegra)
June 3, 2015, 2:16pm
1
Hi all!
Hope someone can give me some insight on this…
Summer’s coming up and wife says it’s time to install motorised shades on some windows…
Obviously we’re both thinking ST integration AND offline usage…
I’m worried about HOW to install the shades… given that the ZRTSI interface ISN’T available in European frequencies…
And she’s worried about the usage if say, the net falls down… how can we pull up (or down) the shades if there’s no internet connection?
Ideas? Thoughts?
Thanks!!!
Every commercially available solution is too rich for my blood. All that I require is blind tilting which can be done with a cheap servo.
I’m embarking on a Particle (Spark) Photon controlled servos to interface with the blind tilting mechanism.
So I purchased a Spark Core a few weeks back and decided to have some fun.
First and foremost a big thank you to @juano2310 , I borrowed and updated your Spark Core device type. It now serves as a dimmer switch for blinds.
So the core of the code is located here:
Things you will need:
A Spark Core
A servo (preferably analog)
Standard horizontal slat window blinds (plantation style will work too)
DIY mentality
Steps
Wire up your spark core with the servo.
Create your Spark Core Blinds device type using the github code
Create your window Blinds device
Load the Spark code to www.spark.io/build
Add the Spark Core device id and access token to the device this can be done on the smart app under preferences for the device.
Put on your DIY hat finally and with your wife’s per…
danielccm
(Daniel Consuegra)
June 3, 2015, 3:58pm
3
I see that! Thanks! But that… unfortunately… is too techie for me! lol! can’t even solder 2 cables together myself!
That’s why I have friends.
I’m terrible at soldering.
danielccm
(Daniel Consuegra)
June 3, 2015, 4:03pm
5
Hey! I just saw this… would it be too hard to integrate with ST?
obycode
(Brice; SmartRulesApp.com)
June 3, 2015, 4:19pm
6
Hi Daniel. I’m not using this myself (yet), but I know a bunch of others talk about it on the forums. Check here - Somfy Motorized Blinds (Z-Wave)
danielccm
(Daniel Consuegra)
June 4, 2015, 2:24pm
7
Hey Brice! I’d love to use that, but Somfy will not sell that device with European Zwave freqs… so I’m stuck with other options… that’s why I asked about the Universal RTS Serial interface…
