Anyone tested some switch for 220v?
Hiā¦Did anyone respond to the 220V solution? Are there any Zigbee switches that are compatible with ST and work on 220V?
I use an Intermatic CA3750 for my water heater. Aeon Labs is working on a unit (with power metering) but no date on when it will be available. But these are both Z-Wave.
I am sure there are other solutions. One would be to use the switch module of your choice to power the circuit of a heavy duty external relay. Most of these solutions are junction box size anyway, so you could easily roll your own.
I use an Aeon Labs Z-Wave Heavy Duty Smart Energy Switch
If you have the right firmware level, the device should pair, and you can use the device type I rwote from this thread
