There are several twist dial zigbee devices on the market, but most of them don’t work with smartthings.
For example, in my own home, we use a lot of the Lutron Aurora dimmers, which work with a hue bridge to control devices connected to that bridge. These work great, and are very intuitive for visitors, but don’t connect directly to smartthings.
Somebody has an edge driver for one of the Tuya devices of this type, called a “smart knob” and sold under multiple brand names, including Moes.
Here’s the link to the edge driver that is working with some of the smart knob models. However, @dennis mentions below that that edge driver does not support the rotational functionality, which is what you would want for this use case. You can get the rotational functionality, but you would have to buy a Tuya hub and connect cloud to cloud.
[ST Edge] Zigbee Driver for MOES 4-Button Scene Switch (TS004F) Plus Some Smart Knob Models
Rotary functions are notoriously difficult to integrate with other platforms, for example, the Hue tap dial switch only integrates the four tap buttons, not the rotating dial, in its integrations, even with HomeKit. Again, you can use it as a parallel means of control with smartthings if you have a hue bridge. But only to control devices connected to that hue bridge.
https://www.amazon.com/Philips-Hue-Switch-Installation-Free-Exclusively/dp/B0B6LLKHTM/
So if you have hue bridge-controlled lights connected to a Hue bridge there are several nice rotary dial devices that give Great dimming Control, including the Lutron Aurora and the Hue tap dial. As I mentioned, I use these in my own home and they work well for visitors.
But if you want to control devices that are not connected to a hue bridge in a smartthings set up, the only one I know of that’s working right now is the Tuya smart knob, and you would need a tuya hub for that. So structurally, it’s similar to the devices that work with the hue bridge, but the advantages that you can bring it into smartthings and use it in smartthings routines.
Hopefully others will post if they know of other similar devices that are working.
