SmartWeather Station Tile- Issues- I think
Have the ST weather thing loaded, in the “new” app I have entered my zip and a weather station ID since I have a PWS. It shows data but it does not match what my actual PWS screen shows and it seems to have stopped updating. I have been searching for days now with now luck, it would appear like the weather thing has never been all that great (by the posts I have read) Any clue why it is is not working correctly? I check live logging on the IDE and it was empty. FYI I am trying to use the weather thing in a WEBCORE piston so that is why I need to be accurate, if there is any other way to use a different weather reporting thing in WEBCORE I am open to hearing about! Thanks
If youre using WebCoRE already check out TWCWeather…
https://wiki.webcore.co/TWC_Weather#:~:text=The%20%24twcweather%20system%20variable%20provides,3.10a.&text=If%20you%20are%20interested%20in,alerts%2C%20try%3A%20%24twcweather.
Wow- Just checked out the WiKi- looks like real good info…if I was smart enough to write the pistons using it…I am not however. :frowning:
