SmartTiles Dashboard 5.4.2 - July 13 (www.SmartTiles.click)
Oh, I am certain. :rage:
Nothing is simple. What are you trying to achieve?
Here’s it installed Alex, looks good!
Was able to steal a 5V rail from my alarm system so didn’t have to use a AC to DC transformer
Can you add support for Smoke/CO detectors? I just added a couple of them, and noticed there is no way to add them to the dashboard? Or am I missing something?
There is no support for smoke detectors at the moment. It’s not high on priority list due to reasons described above in this thread.
[quote=“625alex, post:673, topic:12512”]
[/quote]Ok, thanks! Just wondered why it wasn’t there
Think you could add support for Garage Door Controller capability?
In particular, it would be great to both see the status of the door and be able to click it to open/close.
If you add switch capability to the garage door device type, it shows up/can be controlled as a switch in the Dashboard.
That is exactly what I do with Chamberlain’s MyQ Garage door opener (code from copyninja). It is just a switch on SmartTiles.
I’ve tried that. There are 2 main issues with it, though:
1.) The switch doesn’t actually show the status of the door. It basically just serves as a momentary push-button switch that either opens or closes the door. It should be way smarter than this.
2.) It’s not visually appealing like the rest of the tiles. I don’t see why we can’t use a garage door icon that shows as closed or opened and then triggers the door when you click on it, just like the light tiles.
@brbeaird, @CarlosS
Garage door tile is on the road map. Stay tuned.
You are right, it is just a dumb switch. I have the same problem with my home alarm tile, it is just a dumb toggle switch on SmartTiles. I am glad Alex is adding garage doors in the future, hopefully alarms will also eventually make it.
Sorry if this was posted in the other 600+ post but how do you change the clock to digital?
@Eagle72069 Change it under “Other Tiles” option
Little Bit Of Fun Futuristic Thinking & Vision for everyone :slight_smile:
hope you enjoy,
kyle
@625alex Is there any way to get the camera video tiles to display the video on modern IE 11? I know the tiles are using Flash, and I have Flash enabled for all sites, but the video won’t display at all. The reason I want to use modern IE 11 in Windows 8.1 is because:
  1. It runs natively in full screen mode with no tittle bars.
  2. I got the heck of a deal on HP Stream 7" tablets ($50 each) and I got enough tablets to put them all over the house.
I found that Edge on Windows 10 Beta does play the video feeds in the tiles, but ironically I have not found how to run Edge with no edges.
This looks like a great project. I have a question though. If I am able to add my AVR Receiver to Smartthings to turn on/off, select input, set volume. Is there a tile that could do those functions (specifically set volume or set input) along with updating current volume/input. Or if there is not a tile can i make a tile?
An example device would be like this https://github.com/KristopherKubicki/device-yamaha-rx/blob/master/device-type-yamaha-rx.groovy (i dont currently have this, just trying to figure out what is possible)
Flash is required for Dropcam videos. I haven’t tried or heard anything about the new Nest Cam.
MJPEG cameras should work if browser supports them and don’t require Flash. You can test browser support by entering the video stream directly into browser’s address bar.
You can try another browser, such as Chrome, on this Windows tablet.
There is no such tile, but you can make one by either
  • Create your own tile, using the open source.
  • Create a virtual button tile then map some action to it.
For example, I have a Virtual Momentary Button tile on my dashboard, it’s labeled “TV on” and does nothing in SmartThings. Then I map it via IFTTT to run “watch tv” activity using Harmony channel (since ST/Harmony integration is not working).
Also, if there is a REST API for your device, you can use my Push to GET utility app. This allows you to add a virtual switch tile and call a custom API.
