SmartThings no longer working on Huawei P9
I had to reset my Huawei P9 that had SmartThings installed and now when I try to download the app from Google Play Store, I get a splash notification that - ‘‘This app won’t work for your device’’.
This thing is 8 years old and has Android 7…
Find a version that works here:
This ‘‘thing’’ as you call it is Android version 9 - EMUI version 9.1.0 it has 3GB ram
. The app was working fine until I tried to re-install it.
From the notification your SmartThings app was showing since June (ChatGPT translated):
We would like to inform users of the SmartThings service about an upcoming change.
Support for app updates for SmartThings will be discontinued for Android 9 or lower starting June 24, 2024.
After June 24, 2024, you can continue to use the current SmartThings app on devices running Android 9 or lower. However, it may become difficult to access new features and services supported by app updates, and connecting with some Smart Home devices might be challenging. Please also note that if you delete the app, you will no longer be able to reinstall it on devices with Android 9 or lower.
On devices that can be updated to Android 10.0 or higher, updating the SmartThings app will be supported after the operating system is upgraded. If you have any questions, please contact us via “Contact” in the SmartThings app.
Thank you very much for using SmartThings.
This is not possible since we don’t have access to the app:
“On devices that can be updated to Android 10.0 or higher, updating the SmartThings app will be supported after the operating system is upgraded. If you have any questions, please contact us via “Contact” in the SmartThings app.”
It is very easy to get older Android versions of SmartThings. Go to a site like “APKPure”, find SmartThings, select the version you want, download it and install it and you will be back in business.
