Hello,
I’m aware that my request is quite the oppposite of what we usually see around here but here it comes anyway.
I actually would like to pair a SmartThings leak sensor to my current Zigbee hub.
The hub in question is a Climax alarm system which is ZHA. I bought the leak sensor knowing that it is Zigbee 3.0 and should therefore be backward compatible with my hub. Unfortunately, the device is only recognized as a temperature sensor once connected which totally defeats its purpose.
Is there by any chance something I can do on the sensor side to fix this (e.g. firmware update)? It seems some people had a similar issue even with a smartthings hub in the past but I’m afraid there is not much I can do on the hub side to force a different device handler. It is quite ironic that a company working towards device integration does apparently not produce a sensor that works out of the box despite the Zigbee 3.0 certification.
Thanks for your help!
