I am new to ST and checking things out. I realize that Hub V2.0 release is going to be a couple of months away. I don’t want to invest in the current hub in the meanwhile given the short time frame. Is there anything one can do without the hub? Will any of the sensors work?
Thanks Brian, i had a hunch that would be the case. Trying to tap into ST community wisdom here: what are majority ST wannabe’s going to do? Wait for the new hub ? Seems unwise to invest into the current HUB. Please advice.
You can do quite a lot, actually. I’ve been using ST for several month before I bought a hub. You won’t be able to use any Zigbee or ZWave sensors and switches. But you can use any device that uses cloud-to-cloud integration (e.g. Dropcam and Ecobee thermostat) or any number “virtual” devices. Also, your mobile phone works as a presence sensor without a hub and can receive notifications, etc.
Thanks Geko - very useful info! I have a nest at home, so I can try and integrate that - not sure what would be the need though — nest already has an app that solves most of my needs. BTW, What are examples of virtual devices?
A virtual weather station comes to mind, which basically pulls local weather fo your zip code from Wunderground. Another example is a virtual switch which can trigger IFTTT rule or can be triggered by IFTTT rule. There’s also a number of community-developed projects that integrate “things” or 3rd party services with ST cloud directly, without a hub.
