Hi @Benoit_Ricard
I sent you the welcome code through a DM
I am trying to find out my welcome code as it does not seem to be printed on any stickers on the smartthings hub v2
Hi, @Jay_Frith
Please provide your hub’s serial number
Hi @nayelyz I reset my v2 hub too and need the welcome code, please. S/N 3000369004
Hi @Jay_Frith
I sent you the welcome code though a DM
Thank you so much i will give that a try, very much appreciated.
Hi, could you please help me get the Welcome Code for my SmartThings Hub v2?
S/N: 3000239227
I already did a factory reset, and during setup it only asks for the Welcome Code. It’s not showing as registered to another account.
Thanks in advance!
Hi @soportemty
I already replied via email
Hi @Itati I reset my v2 hub and need the welcome code too. Sorry!!
S/N 3000369004
Scott
Hi @ctgscott
Could you please provide the Welcome Code for this unit?
Model: STH-ETH-200
Serial Number: 3000233611
Hi, @Mike_Drumm
I sent you a DM with the code, please check your inbox. Let us know if you have any issues.
Hi, @E_Winter
I also sent you a DM with the code, please check your inbox. Let us know if you have any issues.
Hello can you help me locate welcome code for serial 3000204744. Please and thank you
Howdy Nayelyz,
I too need to find my code. Can’t seem to add my SmartThings Hub to my SmartThings App without it. My SmatThings Hub Model: STH-ETH-200 SN# is 3000374303
Thank You in Advance,
BBP
Hi
I sent you the welcome code thorugh a DM
Hi @harsh_patel
I reviewed your Hubs, and bouth appears as ‘CLAIMED.’ This means it is already installed on the SmartThings platform, and you won’t be able to claim it with another account. Here are some instructions to reset the Hub:
Please follow these steps:
If you are using batteries for the V2, you should remove them
Factory Reset (Using Ethernet Cable)
- Unplug the hub from power.
- Connect an Ethernet cable from the hub directly to your router.
- Press and hold the reset button on the hub.
- While still holding the reset button, plug the hub back into power.
- Continue holding the button for approximately 15–30 seconds.
- Release the button when the LED changes color (usually flashing yellow or red).
- Allow the hub to complete the reset and enter setup / pairing mode.
- Open the SmartThings app and set up the hub as a new device.
