SmartThings hub sth-eth200 - Welcome Code missing
@achilles1985 @Geoffrey_Parsons
I sent you the welcome code through a DM
Can I get my code, please? Thanks!
Hi @Itati @nayelyz, please can you help me with my welcome code? Many thanks
Good Morning I just Reset my SmartThings Hub and is Asking me on the app for the Welcome Hub to reconnect . Can you please help me on Retrieving this unique code ? Thanks .
S# 3000346078
Hi, Can I get my code for 3000253897
Thank You
Hi @Mjfree @Segundo_Toste_Jr
Hi @JakeyJake3 @dpjohnson13
I reviewed your Hub, and it appears as ‘CLAIMED.’ This means it is already installed on the SmartThings platform, and you won’t be able to claim it with another account. Here are some instructions to reset the Hub:
  1. Connect the Hub via ethernet
  2. Then, follow the steps to factory reset it. Here’s a link that has the instructions for different models:
    Factory reset or reboot your SmartThings Hub
OK did that, can you try again please? I actually have a second one if you could get me the code for that also SSN is 3000131478 first number is a 3 or an 8 it is worn off.
Thank you So much for your help. I was able to enter the code and is working Great .:ok_hand: :wink: :victory_hand: :100:
Will you send welcome code. SN# 3000155390. SmartThings Hub V2
Many thanks @Itati
Hi @Dickyj
Thanks for the response. I purchased this new and lost the Welcome code.
I did a reset and now blue light is flashing.
Richard
Hi @Dickyj
Could you please send us a photo of the serial number on your Hub? We are still seeing the Hub as CLAIMED on our side
Here is the SN. I had the hub working on the older app. But it quit working.
Richard
Hi @Dickyj
Unfortunately, the reset was not successful, and the device still has a CLAIMED status.
The engineering team has informed us that if performing the reset is not possible, it is highly likely to be a hardware issue with the device. Please try resetting it once again by following the instructions in the video below.
Factory Reset Samsung Smart Things Hub
Please let me know the result.
First it’s blinking blue
then solid blue.
Now the LED is solid green.
Thanks for your help with the unit.
Richard
Hi @Dickyj
I sent you a DM
