Smartthings/Home Assistant integration error message
When I try to integrate smartthings I receive error message “Le flux de configuration n’a pas pu être chargé” (The configuration flow could not be loaded).
I tried with duckdns and also home assistant cloud but without any success.
Thank you in advance for your help.
Could it be related to Version 2021.3 smartthings integration breaks · Issue #47449 · home-assistant/core · GitHub where the config flow error was a result of not having configured an external URL?
I know nothing about HA, I just Googled, so I can’t add any insight.
I am not sure because I configured an external URL correctly but since that, I cannot add the integration. But it is strange because before the installation of external url I could click on this integration.
@cedric_bailleul, you will have better chances if you ask the same question on the HA community forum, or post an issue on GitHub regarding the integration.
