New here, but couldn’t find answer on community.
I am waiting for my first ST v3 hub to arrive. I am renting out a cottage (2hrs away) and was planning to set it there in order to monitor temperature & humidity and control the Samsung A/C device (connected to cottage WiFi). Idea is to set the A/C on, once temperator or humidity moves below certain limit.
Now the question part: In the cottage I have a 4G WiFi router for Internet connection. I have changed the default password (something like ‘123aBc!"#’) into something more memorable for the guests to use.
However, it happened couple of weeks that our guest resetted the WiFi router to factory settings, and the “easy password” setting was erased.
Would it be possible to create 2 connection settings so that ST would be able to connect to router using either:
a) EASYROUTERNAME & password: ‘qwerty’
AND
b) DEFAULTROUTERNAME & default password: ‘123aBc!"#’
This way, I could always form a connection even if the router was resetted to default settings. Thank you for answers already!
