Hi Smartthings Support Team,
I am getting confused with the example defined in documentation on how to create tiles.
I was using this example to create an interface for my custom device handler.
Here is what it looks like
Here is my code
metadata {
definition (name: "CC1352 Sample Switch", namespace: "smartthings", author: "SmartThings") {
capability "Switch"
capability "Refresh"
capability "Temperature Measurement"
// Generic
fingerprint profileId: "0104", inClusters: "0000" , outClusters: "0006", manufacturer: "TexasInstruments", deviceJoinName: "CC135R1 SWITCH"
fingerprint profileId: "0104", inClusters: "0000" , outClusters: "0006", manufacturer: "TexasInstruments", deviceJoinName: "CC1352R1 SWITCH"
tiles(scale: 2) {
multiAttributeTile(name:"sliderTile", type:"generic", width:6, height:4) {
tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "off", label:'${name}', backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', backgroundColor:"#79b821", nextState:"turningOff"
attributeState "turningOff", label:'${name}', backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute("device.level", key: "SECONDARY_CONTROL") {
attributeState "level", icon: 'st.Weather.weather1', action:"randomizeLevel", defaultState: true
tileAttribute("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel", defaultState: true
multiAttributeTile(name:"valueTile", type:"generic", width:6, height:4) {
tileAttribute("device.level", key: "PRIMARY_CONTROL") {
attributeState "level", label:'${currentValue}', defaultState: true, backgroundColors:[
[value: 0, color: "#ff0000"],
[value: 20, color: "#ffff00"],
[value: 40, color: "#00ff00"],
[value: 60, color: "#00ffff"],
[value: 80, color: "#0000ff"],
[value: 100, color: "#ff00ff"]
tileAttribute("device.switch", key: "SECONDARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'…', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
attributeState "turningOff", label:'…', action:"switch.on", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute("device.level", key: "VALUE_CONTROL") {
attributeState "VALUE_UP", action: "levelUp"
attributeState "VALUE_DOWN", action: "levelDown"
valueTile("power", "device.power") {
// label will be the current value of the power attribute
state "power", label: '100'
main "switch"
details(["switch", "refresh"])
// Parse incoming device messages to generate events
log.debug "description is $description"
def event = zigbee.getEvent(description)
if (event) {
sendEvent(event)
log.debug("this is goooooooooood")
else {
log.warn "DID NOT PARSE MESSAGE for description : $description"
log.debug zigbee.parseDescriptionAsMap(description)
def off() {
zigbee.command(0x0006,0x00, "", [destEndpoint: 0x09]);
//zigbee.writeAttribute(0x06, 0x00, Integer dataType, value, Map additionalParams=[:])
//zigbee.off()
def on() {
//zigbee.on();
zigbee.command(0x0006,0x01, "", [destEndpoint:0x09]);
def setLevel(value) {
zigbee.setLevel(value)
def refresh() {
return zigbee.readAttribute(0x0006, 0x0000) +
zigbee.readAttribute(0x0402, 0x0000) +
zigbee.configureReporting(0x0006, 0x0000, 0x10, 0, 600, null)+
zigbee.configureReporting(0x0402,0x000, 0x09,0, 600,null)
//return zigbee.readAttribute(0x0402, 0x0000) +
//zigbee.configureReporting(0x0402,0x000, 0x09,0, 600,null)
def configure() {
log.debug "Configuring Reporting and Bindings."
return zigbee.configureReporting(0x0006, 0x0000, 0x10, 0, 600, null) +
zigbee.configureReporting(0x0008, 0x0000, 0x20, 1, 3600, 0x01) +
zigbee.readAttribute(0x0008, 0x0000)
And also, I would like to ask, would it be possible to display these tile in the new smartthings app?
