Sure, I am still working on a few things. But here is what I have now.
Make sure you put the ZXT-120 into continuous listening mode (must be done with the device unpaired, see the instructions), then attach it to a usb charger…it works much better this way. I tried on battery at first and it didn’t work well. That was before I coded changes so maybe it works better now. If you try let me know.
After installing with this device type make sure you do the following.
Open preferences, enter your desired code and other prefs.
Then tap "config"
When the Config# tile displays the code you entered in prefs you know the config worked.
I started with a version I got from b.dahlem and heavily modifed.
A few things I am working on
Adding learning (although I don’t need it any more since codes provided are working well)
fix sliders to work for Celsius
The sliders in ST APP are hard coded to range from 0-100 so what I did was restrict the setting from 67-84 which are the zxt-120’s limits. So if you slide to anything below 67 it pops up to 67, anything above 84 it pop’s down to 84. I hate that can’t make the entire slider range from 67-84 which would make it MUCH easier to select a value but this is a limitation of ST sliders (there are threads requesting enhancement of this for quite a while)
I only enabled the Cool, Dry, and Heat tiles. There is also an Auto tile but I don’t display it because I don’t use it. I don’t know what “Emergency Heat is” so I don’t show that one either.
How about using Arduino UNO project called Universal Learning IR Remote.
We can setup the remote that we want to replace.
For example, we want to clone Split AC system IR remote. We can capture IR ‘code’ from every button on remote. And transmit the same IR code with infrared transmitter that connect to Arduino.
After arduino IR remote can replace the AC remote, then we connect it to ST with Smartthings Arduino Shield.
For feedback, smart plug or any device that can measure the power consumption. The amount of watt will be different when the AC is operating or not, with this we can determine whether the AC is ON or OFF.
This is one example of Universal Learning IR Remote
Split systems don’t typically have a plug. My units are all 240V 30amp so you would need a power monitor that can be wired inline and support that output. But I like the idea, for feedback on my unit I use a remote camera to see if the vents are open which means the unit is running. I also use a temp meter to see that the temp is changing as requested.
Ahh you are right, it’s so high current.
But, what do you think about Universal remote that use Arduino ?
Is it possible to make ?
If this possible, I need to create Smart App that looks like remote, isn’t it ?
For example, I create 3 button function, 1 for power and 2 other for up and down temperature.
I never create any smart app before, is it hard to create ?
How would you interface with the remote ? I tried to watch the video but it was a little hard to understand what they were doing. They were soooooo boooorrrrring
Anyway if you can get an interface to the remote then depending on what that interface is you could write a device or a smart app. The ZXT-120 which I am using has a zwave interface so I am able to write a thermostat device to make it work. It also has a learning mode so you would need to add the learning features to the device but that is very doable.
I also have a Harmony Home Hub which I may try to teach my AC signals. However harmony integration with SmartThings is broken right now and I don’t know if it will ever be fixed.
Haha, it’s true so boring. I only watch half of it.
The only way to connect the Arduino is by ST Arduino Shield.
First, I need to build the Universal Learning Remote on Arduino. Some people has done with this.
After that, attach the ST Shield so it can connect to ST hub
I’m haven’t try it yet, because I don’t have the ST Shield.
Since last harmony firmware upgrade you can’t connect the harmony to ST and have ST control it anymore. I think the harmony can still trigger ST actions but I have not tried because that is not how I wanted to use it.
I created your device type and set the AC unit code, but it seems I can only turn the ac on/off and change the modes (dry, cool, heat). Changing the temperature slide has no effect. I have tried all of the AC unit codes. Is there something else I need to configure?
I don’t really know. My split system doesn’t report the temp it is set to so I have no idea if this even works for my system. How do you know temp isn’t working.
The way the temp works is setting it only sets the temp on the ZXT-120. The temp isn’t sent to the unit unless you press cool/heat. It is the cool temp setting and heat temp setting which is issued when you turn either mode on.
has anyone in the community gotten their sensibo units yet? curious to see if we can get it to work with ST. Or even the Tado unit that was on kickstarter?
Didn’t know about this. Looks cool. I wonder how it learns your AC ir commands. They don’t seem to explain that at all.
I would like to get one of these. I clicked on buy and it added $20 “International Shipping” Don’t they know Hawaii IS in the United States
I would like to know how the IR learns anyway before paying $159 for one AC and $80 for each pod (I would need 4 more)
Their ordering system doesn’t let you put more than one “Product” in the cart either so I would have to Pay the $20 international shipping once for the main system and again for the extra pods.
Honestly if they can’t program a simple shopping cart I am not sure I trust their device LOL
haha yes. well they are both startups so that probably explains it. I backed both of them. Sensibo seems like it’s closer to shipping tho (already shipped dev kits out)
Tado seems like just a thermostat to me, does it also issue IR commands ?
My AC is also my Heat (Split System Heat Pump) perhaps you are interested in the later device for heat and the former for AC ?
I emailed Sensibo sales. If the IR commands learn I would prefer it over the ZXT-120 's I am using. I have $210 invested in three ZXT-120 devices but I haven’t codedd the device code to learn yet, it is a very complicated process. If the Sensibo learns like a Harmony or better yet learns as you use the remote, I would be VERY interested in this device.
Still scares me that they can’t create a simple shopping cart
One other option I didn’t see it listed yet, if your air-conditioner can be controlled by a Logitech Harmony remote, you can get some integration with SmartThings that way.
I have a question i am new to the smart home concept. I purchased rhe smartthings outlet ans plugged my window ac u it to it, the device is paired but it will not turn on my ac. It is working like a power surge protector, cutting off complete power tl the outlet. I also tried it with my bluetooth samsung sound bar, it does the same thing. It only seems to work with devices that do not need on and off switches, does anyone know of a work around?
The problem isn’t so much between devices with on/off switches vs those w/o on/off switches, it’s such that your AC likely stays off when it loses power and doesn’t turn back on when reintroduced to power. This is actually a safety condition as turning the compressor on and off quickly can be damaging. So, in case of a quick power outage, the AC will not kick off and then back out if power is lost for a few seconds. The sound bar must be the same way, of course not for the same reasons, it just not smart enough to turn itself back on until someone actually pushes a button. It’s not a mechanical switch w/ a distinct on/off position.
So as previously mentioned, you would need some kind of device that could turn the AC back on. There are a few devices out there but they are pricey. Tado, Sensibo and Ambi Climate are the major options, can’t remember which currently work with ST and which just say they are working on it. In my opinion there isn’t an ideal solution at the moment. The Ambi looks good on paper if it works with your AC but you’d have to buy a unit for each AC and the expense per unit is probably more than the AC itself. They should have gone the way of most smart devices and created a central hub w/ add on temp sensor/IR units. Also, don’t think they’ve integrated with ST as of yet. They’ve been saying they are working on it since inception which has probably been a over a year if not more.
