I have synced up smarttag2 with smartthing. But it always shows same location as Samsung device even when tag is few kms away. The ration was to track the cycle location but even if the cycle is kilometers away it doesn’t show up. Is there any other setting to be done. I’m sure there would be Samsung device in couple of kms distance in place india
The “Share this device’s location” enables the tag to share its location with another person assigned to your account. The tags do not need that enabled to work. The tags need UWB (ultra wide band) enabled for close location. If you are not in possession of the tag and it doesn’t show on your phone, then, either the battery is dead or the tag is not in the vicinity of other SSung phones.
