Am I missing something? I created this from the SmartThings Samsung App.
Is it because the button is an “IKEA Tradfri Remote” button and that runs in the Cloud? Or are there other settings I need to change?
Sorry, very new to this…
Nige
Smartlighting Automations are local ONLY if everything in the chain is local (usually the culprit is the device handler) AND if you don’t use an advanced calculation in the automation that would make it run in the cloud. (For instance, if you’re turning on or off, setting values or colors you should be fine, but say if you wanted something to fire on a recurring basis at Sunset, your hub needs to be online at the time it calculates sunset for TOMORROW’s trigger…)
So like I said the DTH is usually the culprit. to get local ops on your devices.
So what Devicetype is your Ikea Remote?
Thanks Nathan, brilliant information.
I did wonder if that was the issue. The IKEA multi button device runs in the cloud and has a custom handler as part of smartthings . Thus no chance of that being local ![]()
Thanks again, have a great weekend!!!
Nigel
