plboucher
(Pier-Luc Boucher)
#1
Hello Smartthing community
first post in here, new to smartthings hub
Simple question for the smartlight apps, when we add a trigger to launch them automatically, is that an AND or an OR between those triggers?
If I add a trigger to open a light when my cellphone change to present OR the door open, is that possible?
thanks!
Smart lighting only allows one trigger. So in your case you would create two rules: one for arriving and one for door opening.
plboucher
(Pier-Luc Boucher)
#3
Ok thanks, also found that I could use webcore to trigger that kind of routine
thanks
Yup, wasn’t sure if you wanted it to run local or not or if you had webcore.
