Smarthings/Alexa with Schlage Connect
You are able to lock the door or ask for it’s current status. Unlock by voice isn’t supported for Alexa, kind of security issues.
Iˋm able to do it with a smartapp, setting the action there and set the app to be trigger by a routine. That way you can ask Alexa to turn on the routine.
Here is one related topic for a similar app, take a look there and in the forums, if you really want to setup your ST system, I will need to learn this kind of tricks. Good luck!
