Smartenit dual load
Anyone have any luck with this? Was thinking of get it it to control my 2 speed pool pump. Looks promising but then again…
I think right now it will pair as a SmartPower Outlet and will only be able to control both loads at the same time and not individually.
Cool so I can control the on/off function just not the 2 speed. Thanks
Bumping this to see if there is any progress. I want to use ZBMLC30 for my baseboard heating, with two 30A zones.
I notice in the quick start guide you can bind to load 1 and load 2 by pressing the buttons on the front. Does that make it appear as two smart switches?
http://sandbox.smartenit.com/downloads/ZBMLC30_Quick-Start.pdf
One more bump.
It is kinda annoying to have a switch with 3 relays and use it as one.
If anyone from smartthings team looking at this post please tell us if this limitation is hardware/driver or it is just app is not capable to handle situation. I can volunteer to create app which will handle 3 relays for one device.
Please reply. Thank you.
To contact smartthings staff write to support@smartthings.com
We (Smartenit) worked on a handler for this. I commented about that on a different thread, but I’ll copy it here:
We have created a device handler for the ZBMLC30 with metering support and to control both loads. Link here:
