Hello
Im a bit new at this but big fan of Smartthings, I have just bought a couple of 17103 Double Smart Switches, but I can
t get any smartapp to manage each switch individually… Tried to ut se one coded but maybe I have not perform all the steps.
Would really appreciate some help, otherwise maybe I bought the wrong switch??
Regards in advance…
Which device type handler are you using?
erocm123 : Aeon DSC17103 Micro Double Switch
is that OK?
Yes, that should work. You usually get your quickest answers by asking in the author thread where you got the code. In this case:
Just got one of these and wanted to create a proper handler for it. I have been using a Philio Pan04 in one room of my house for a while (which has been great), but didn’t like the ~1 second delay when pressing the physical switch (all my other switches are instant and I am a perfectionist).
I am not a huge fan of this device because 1) It’s a tad larger than other dual relays, and 2) Its terminals did not fit my 14 gauge lighting wire. I expected this from the 3v switch terminals, but not the line, load, and neutral terminals. I had to squish the wire just a tad to get the terminal screws to thread.
Anyway, here is the device handler for it. It has some configuration options to fine tune things (if that is how you roll).
[image] [image]
[image]
And of course, to use both switches …
That way not only does the author get flagged, but anyone else who has been using that specific device type handler can answer your questions.
Already wrote a note to the author, thanks for the support
If you post your question in the author thread, other people will see it, so you may get an answer sooner than if you wait for the author.
Thanks being new at this is a bit challenging?
That’s true for everyone! SmartThings is very powerful and versatile, but definitely not intuitive. Fortunately, the community is always very helpful.
