I just bought and installed Aeon Labs MICRO DOUBLE SMART SWITCH DSC17103. As I ran the “Add a thing” through the App, It only came on as a single switch, and I can either turn both switches on or off from the “Things” menu. The work well manually, I can turn them on or off independently this way, but from my phone, it´s either both on or off. Has anyone encountered this? Is there a way to correct this? Your input will be greatly appreciated.
Yup, still doesn’t support two of the same capabilities in single device using the stock apps and device handlers, there are a few exceptions though. I have a device type I wrote for this switch. You will need a custom smart app to control the second switch, though you can use the second switch from the device details panel.
