Depending on how much amperage the Fan needs, I would think that a GE on/off z-wave switch should work. You will need to assess this yourself, as depending on the age of the house you may not have the necessary wiring to make these switches work correctly.
How old is your house, and do you know tha tyou have Hot, Ground, and Neutral available?
The wemo is rated at 1800w resistive and 600w max load. I know the linear is similar. The Ge won’t be far off either. You might want to look at the fan as suggested by Edward. A z-wave relay would probably be best.
Says online “Compatible with incandescent, fluorescent, compact fluorescent, xenon, halogen and LED lighting up to 960-Watt” so maybe the extra 360 watt’s will be sufficient to make it work ?
@mwhaley99 I’m using the Wemo Light Switch to control my 200W whole house fan and it works great. I did have some problems too initially when the Ground was not properly connected so you might want to check out your lines with an outlet tester.
So I tried the 3 way GE Fan switch and same issue, when I went to turn on the fan it would briefly engage for less than a second and turn off, think the load is too much for it, damn.
