I have a belt driven whole house attic fan operated by a dumb high/low switch. Low down, off middle, high top.
I see some have used a regular Zwave GE switch, but that would allow only the high setting.
Anyone have any other ideas for a Zwave or Zigbee switch? Does anyone make something that would be low, high, off in Zwave or Zigbee?
MarkTr
(MarkTr)
September 17, 2018, 4:21pm
2
Lots of conversations about this if you use the search function. Here’s a recent one:
I had the same situation with my fan. There was a hi/lo switch and the on/off with timer.
What I did was remove the on/off with timer module and replace it with a GE in wall on/off paddle switch. I left the hi/lo in place because I didn’t feel that there was enough need to figure that one out. lol.
I use automation with my fan and it works great. Basically I have rules that when it turns on it checks to make sure there are XX number of windows open. If there aren’t enough windows open it turns off and alerts me about the windows. It also turns off the thermostats when it turns on. When it turns off it announces what windows are open, this way I do not have to check every window in the house. It also turns the thermostats back on and sets them for the appropriate mode.
It would be nice…
MarkTr
(MarkTr)
September 17, 2018, 8:55pm
4
tuffloud1:
I did see that thread.
If you have specific questions that aren’t already answered there, just reply on that thread; then people who are already knowledgeable on the subject can help you out. From the details you’ve provided so far, it sounds very similar to other users’ situations so what worked for them will likely work for you.
