I have an issue with the SmartThings Internal “Smart Lighting” application. It is my understanding that this is the appropriate way to automate lighting.
Here is my dashboard - with the annoying default image that I cannot amend - showing the Things I have connected:
Try picking a level. I think because it’s a dimmable device, it wants you to use turn on and set level instead of just turn on. I know that should gray out the other option if you’re not supposed to do it, but just try this and see if it makes a difference.
Either that or it’s part of the current poltergeist weirdness. (I have a switch which is neither on nor off right now. )
Also, go ahead and report it to support@smartthings.com with the screenshots, in either case you shouldn’t be getting the authorization message.
Well, SmartThings crew, I don’t know what you did - but it worked! I tried to access the Smart Lighting section tonight and BAM, the Triggers were available!
