Can't create lighting automation in WP app
I had a problem creating a lighting automation, I don’t know if this is the right place to report, but here is the description:
I wanted to create a lighing automation, but in the creation step, the application fails with an "Error: Connection failed.
I made the following steps:
  1. Dashboard -> Add
  2. Go to SmartApps
  3. Got to Lights & Switches
  4. Select Control and automate Lights and Switches
  5. Tap New Lighting Automation -> Error: Connection failed [Red banner]
    I tried it several times and always fails with the same error.
    I tried it in my wife’s Android phone and it works ok.
    I hope it can be fixed soon.
    Thank you.
    Gabriel
@gabrielgesto Can you send a report to support@smartthings.com? They should be able to help you out. It’s possible the SmartApp depends on features only available in the new iOS and Android apps, but I’m not sure.
Ok, I’ll do that, thanks!
Gabriel
