Smart Life/Upstone WiFi Bulb
Has anyone had success getting these going with SmartThings?
UPSTONE Smart WiFi Bulb LED Smart Switch RGB Multicolor Works with Alexa Google Home Assistant https://www.amazon.com/dp/B071CNQ6BQ/ref=cm_sw_r_cp_apa_1oT0zbHH1DK68
It uses an app called Smart Life to integrate with Google Home and Alexa.
Additionally, I found this: http://smartlife.tech/blog/2017/06/19/smartlife-devices-wifi-smartthings-configuration/
I loaded the Smart App, but it never locates the bulb.
Did you install a device handler for the bulb first?
I didn’t. I can’t find one. :frowning:
Looks like that got me a step closer, but still no luck.
It won’t automatically discover the bulb.
I am able to manually add it by IP, and it seems to see it as a valid device; however, it doesn’t configure it.
The smartlife controller doesn’t work with bulbs to my knowledge. This device handler is for a custom flashed RGBW controller the H801. I think it’s just luck that both have the name SmartLife and are not associated.
That may very well be. I have no familiarity with this device, was just going with info provided by OP.
@JScottTuck you should ask @erocm1231 if he can assist since it’s his smartapp and dth.
Yeah, I don’t think that bulb is supported by SmartThings. Just has Alexa integration and Android App control with whatever app they are recommending.
I was wondering about these Upstone bulbs too. I just can’t see spending $50 per bulb for the big name brands. These Upstone bulbs at $18 each and Q&A says they are about 60W equivalent. I’m about 50-50 on whether or not the reviews are real though.
They were noticably less bright than my Hue bulbs. I sent them back due to the lack of integration. I have a couple of these on the way: https://m.gearbest.com/smart-lighting/pp_710443.html?utm_source=email_sys&utm_medium=email&utm_campaign=shipping
The website indicates that they will attach up the Hue Hub. I guess we’ll see!
Thank you for the feedback. One of the more legit looking reviews on amz mentioned the lack of brightness too. Let us know how the Jiawen bulb looks! Picture #4 at the link you posted is an interesting photoshop I suspect. They show it hanging upside down by a wire, bulb on, but not plugged into a socket.
I know this is old but you can actually control it through ifttt. Just create a virtual switch in smart things and have that switch when activated run an ifttt applet to do what you want. I use this setup in a nighttime routine to turn everything off.
Hi are you sure about this?, because the problem I have with Smartlife devices in IFTTT is it shows me the power switches I have but the bulbs never show up in IFTTT so I can’t control bulbs. (actually in the smartlife app it shows the bulbs as compatible with Alexa and Google Home but not IFTTT)
Have you managed to overcome this ?
I have lots of Smartlife bulbs and would love to be able to integrate them better
Just landed here based on the B071CNQ6BQ barcode my google lens was able to pick up.
Not a smartthings users, but was able to flash this same “Upstone Smart RGB Blub” with tasmota firmware OTA with Tuya-convert.
AiLight(27) template in tasmota has the correct GPIO mapping.
Maybe this helps somebody else.
