Popp has an electronic strike zwave device which should work, but is expensive:
And as you mentioned, the Yale cabinet lock is supposed to be available in the UK but I see Amazon has it marked as not currently available, so I’m not sure what’s going on there. End it looks like it may only be Bluetooth, so it would not integrate with smartthings Except perhaps with Alexa as an intermediary. Maybe check with Yale to see.
Other than that, there are things you can put together with third-party intermediaries or building something yourself but those all get pretty hacky and are more vulnerable to failing.
