Smart Charger, shutdown washer
(Martin Newham) #1
I’ve looked at the SmartThings market, but couldn’t see anything that would switch OFF a socket if the power usage dropped below a set level.
Thought this would be useful to power off washers once the machine stopped drawing significant power, or to cut power to a charger when the car/device battery was full (not drawing any more power).
#2
Here you go (Work with ST outlet currently)
(Martin Newham) #3
Cool, I’m new to this coding in ST, is there a crib sheet on what I need to do, and get it onto my hub?
#4
You need to sign up an developer account, then add the code into your smartapps section. Search the forum, there are guide.
(Martin Newham) #5
Got it! BIG thanks, my first app is yours!
