Hi guys,
IMPORTANT NOTE: Because as a newbie I can only write two links per post, in this question <SOME_LINK> = https://i.ibb.co/594ZrT9/Crud.png
I am using the Smart App node js SDK to build a Smart App that requires to display an image in one of the settings.
I am trying to create the image setting in this way inside a section definition:
section.imageSetting(’<SOME_LINK>’)
But the imageSetting does not compile to valid image setting configuration as describe here:
In place of a valid image setting in the generated page I am getting this JSON:
“id”: “<SOME_LINK>”,
“required”: false,
“type”: “IMAGE”,
“name”: “pages.setupPage.settings.<SOME_LINK>.name”,
“description”: “pages.setupPage.settings.<SOME_LINK>.description”
It is not a valid image setting because it lacks the properties “height”, “width” and “image”.
Also the ImageSetting js class does not has methods to define these extra properties.
I think this is a bug in the SDK.
Has anyone faced this problem before?
If yes, how do you solved it?
Regards.
