SimpleLink WiFi & SmartThings
Hi,
I am trying to get a SimpleLink WiFi device to connect to the SmartThings hub. Does anyone know about how to do this? What WiFi specs does the SmartThings hub run on? Does it use MQTT or HTTP? etc. I’d appreciate any help.
If you mean the standard Samsung smartthings home automation hub, it doesn’t have Wi-Fi at all. Connections to Wi-Fi devices are either cloud to cloud or a custom LAN integration. So you need to find an API.
If you mean the SmartThings Wi-Fi mesh router, you need to talk to Samsung support on that one.
