Hi - I have two zwave plug in lamp modules in my bedroom. I am wondering if there is a simple way to go into the smartthings app and create a virtual device of some sort that I can just use to set the dim level when I want to dim both lamps. This would be much easier than having to go and dim each device individually.
I tried going into home tab, then tapping on Lights and Switches, and then onthe Shortcuts tab. I was able to add a “device” there which is great for turning both lamps on or off at the same time, but it doesn’t let me dim.
