I am using the Ridiculously Automated garage door smartapp to control my Linear GD00z garage door controller. I have it set to automatically close within 10 minutes. There is a line in the app that you can change to Yes if you don’t want it to close automatically and want to bypass the open checks if you are home and working in and out of the garage. The problem with this is it is easy to forget to change it back.
Is there a way to add a smart toggle on the garage door section within the smartthings app that you could toggle to have it bypass these checks instead of having to go into the smartapp to change then save it every time? Or is there a option already available that I am missing?
