Hello, I just picked up the Linear Garage door controller and can’t figure out how to do the following: between 10pm-7am, if the door is open for 15 minutes, i’d like it to be closed automatically. Any ideas?
You can do this in webCore, are you looking for a standard app to do this?
Just looking for what automation to use and how. Don’t care if it’s webCore or other. Tho webCore is having issues for me right now … when I try to make a piston, the options screen is blank. Need to uninstall it and reinstall I guess since it isn’t clearing up on its own.
Go into the Graph API and updated the app there. You probably out of date ver there.
You can also try to use CoRE as a stand alone app. Otherwise if you have access to RBoy Apps you can use the Garage Door SmartApp which automatically opens/closes doors after a certain period of time amongst other features. [RELEASE] Enhanced Linear GD00Z-4/GD00Z-5/GoControl/Iris/others Device Handler with Switch and Automated Garage Door Open/Close when People Arrive/Leave/Timed
Thanks for the tips guys … I can always count on multiple people on this board to have the answers! FYI I used the cut-and-paste method to install webCore, if I get a git account and do it that way will I get updates automatically? And what’s Graph API?
Using git won’t push updates automatically, but it will be a little simpler to know when there are updates and manually pushing the update into SmartThings.
That’s simply the Classic SmartThings Web IDE.
