Make sure garage is closed when set to away
I can set to double check that my doors are locked but is there any way to close my garage door if it was left open for some reason. I would have thought it would be right under the make sure doors are locked. but I can not find the option.
Try this on for size :slight_smile: It will alert you if you left it open. Then you can open teh app and close it.
https://github.com/tslagle13/SmartThings/blob/master/Is-My-Home-Secure/Is.My.Home.Secure.groovy
Cool thanks. You would think this would be a default option.
