I’m trying to create a CoRE Piston to increase the current Nest temperature to the current room temperature plus 2 degrees. I can read the room temp and create a variable with the increased setting, but I can’t get the Nest to receive this back. I’ve tried ‘Load attribute from variable’, which appears to do nothing. I’ve looked at simply setting the temperature, but that will only accept a number - not a variable. I’ve also validated in debug that my variable is getting set correctly.
Any ideas what I’m missing, please?
