@storageanarchy for vis
I’m trying to set multiple program setpoints in webcore depending on outside temperature, but when i confirm via the ecobee app, it appears that only the active program is being updated? i can’t seem to find any errors in the logs. here’s the webcore piston:
here are the webcore logs:
1/11/2020, 5:59:59 PM +59ms
+1ms +Received event [Home].time = 1605139200000 with a delay of -941ms
+103ms ¦RunTime Analysis CS > 25ms > PS > 40ms > PE > 38ms > CE
+107ms ¦Runtime (38728 bytes) successfully initialized in 40ms (v0.3.110.20191009) (105ms)
+108ms ¦+Execution stage started
+214ms ¦¦Comparison (dynamic) 74 is_less_than_or_equal_to (integer) 55 = false (2ms)
+217ms ¦¦Condition #3 evaluated false (93ms)
+218ms ¦¦Condition group #2 evaluated false (state did not change) (96ms)
+221ms ¦¦Cancelling statement #4's schedules...
+2207ms ¦¦Executed physical command [Thermostat 1].setProgramSetpoints([Sleep, 67, 69]) (1973ms)
+2208ms ¦¦Executed [Thermostat 1].setProgramSetpoints (1975ms)
+3937ms ¦¦Executed physical command [Thermostat 1].setProgramSetpoints([Home, 72, 75]) (1723ms)
+3938ms ¦¦Executed [Thermostat 1].setProgramSetpoints (1725ms)
+3940ms ¦+Execution stage complete. (3833ms)
+3942ms ¦Setting up scheduled job for Wed, Nov 11 2020 @ 7:00:00 PM CST (in 3597s)
+3971ms +Event processed successfully (3971ms)
and here are the live logs:
ecobee suite mgr 6:00:08 PM: trace updateSensorData() - sensorCollector being updated with sensorData: [Away:on, Home:on, Sleep:on, activeClimates:[Away, Home, Sleep], programUpdated:2020-11-11 18:00:08, climatesUpdated:2020-11-11 18:00:08]
ecobee suite mgr 6:00:08 PM: trace updateSensorData() - sensor Bedroom is used in [Away, Home, Sleep]
ecobee suite mgr 6:00:08 PM: trace updateThermostatData() - Event data updated for thermostat Living Room (311014448992) = [[lastPoll:full @ 2020-11-11 18:00:08 CST], [programUpdated:2020-11-11 18:00:08], [climatesUpdated:2020-11-11 18:00:08]]
ecobee suite mgr 6:00:08 PM: trace Updates sent (267 / 1495ms)
ecobee suite mgr 6:00:08 PM: debug updateSensorData() - Sensor Living Room, sensorDNI == ecobee_suite-sensor_tstat-ei:0-Living Room
ecobee suite mgr 6:00:08 PM: info pollEcobeeAPICallback() - Parsing data for thermostat (311014448992)
ecobee suite mgr 6:00:08 PM: debug updateSensorData() - Sensor Bedroom, sensorDNI == ecobee_suite-sensor-rs:100-M4XX
ecobee suite mgr 6:00:08 PM: info Living Room -> scheduledClimateId: home, scheduledClimateName: Home, scheduledClimateOwner: system, scheduledClimateType: program, climatesList: [Away, Home, Sleep]
ecobee suite mgr 6:00:08 PM: trace updateThermostatData(Living Room 311014448992) - currentClimateRef: home, currentClimate: Home, currentClimateName: Home, currentClimateId: home, currentClimateOwner: system, currentClimateType: program, thermostatHold: null
ecobee sensor 6:00:08 PM: info Updated 6 objects (52ms)
ecobee sensor 6:00:08 PM: trace generateEvent(): parsing data [Away:on, Home:on, Sleep:on, activeClimates:[Away, Home, Sleep], climatesUpdated:2020-11-11 18:00:08, programUpdated:2020-11-11 18:00:08]
webcore routine 5:59:59 PM: info + Received event [Vavas].time = 1605139200000 with a delay of -941ms
webcore routine 6:00:03 PM: info + Event processed successfully (3971ms)
webcore routine 5:59:59 PM: trace ¦+ Execution stage started
webcore routine 5:59:59 PM: trace ¦ Runtime (38728 bytes) successfully initialized in 40ms (v0.3.110.20191009) (105ms)
ecobee thermostat 6:00:01 PM: debug generateEvent(): parsing data [[debugEventFromParent:setProgramSetpoints(Home) - heatingSetpoint: 72°F , coolingSetpoint: 75°F (info)]]
ecobee thermostat 6:00:01 PM: debug getDeviceId() returning 311014448992
ecobee suite mgr 6:00:01 PM: info setProgramSetpoints() for EcobeeTherm: Living Room (311014448992): Home, heatSP: 72, coolSP: 75)
thanks,
matt
