Another question for you
When using the security smart apps in smartthings, is there a way to add a pin code to deactivate the alarm?
Is there a way to add a delay before the alarm goes ON ?
Thanks a lot!
Thanks a lot!
Exit and Entry delays are supported with the SHM_Delay smartapp
Pin Codes there are a few choices
Using an Iris/Xfinity/Centralite keypad with this Lock Manager smartapp and the SHM Delay smartapp
Use a Smartlock
No Keypad or Smartlock: The ActionTiles smartapp supports one pin code. Subscription required after trial period.
