Hello,
I am very new to creating smart apps and DTH. I have Smart Home Monitor installed now and it works great, but I just picked up an iris keypad in the hopes of using it to arm and disarm the system. I did the smart app 3400- keypad monitor and it does allow me to arm and disarm the system but there is no delay. I have been reading other posts that says Smart Alarm has a delay option but have no clue how to get it, Do I have to somehow uninstall SMH before creating the smart alarm app? Any help would be greatly appreciated.
Take a look at my app SHM Delay. It works with Smart home and Lock Manager .[Release] Smart Home Monitor Exit and Entry Delays
I tried installing from Code and I get the following Error - Metadata Error: Parent SmartApp ‘arnbme:SHM Delay’ not found
I tried installing from the repository and it said
Oh No! Something Went Wrong!
Error
500: Internal Server Error
URI
/ide/app/doRepoUpdates
Reference Id
1dc0d0c9-876e-48dd-a387-7d121afb69a0
Date
Thu Sep 28 21:43:31 UTC 2017
No idea what is going on, but let’s try to get this installed.
In the SHM delay app documenttion threre are install instructions and a quick start guide
1 First do module SHM Delay, save and publish in the Ide
2 Then do modules SHM Delay Child and SHM delay mode fix, do not publish. if you did not a problem. These are child apps that require SHM Delay.
3 In the phone app add a smart app. Add module SHM Delay setup and install it
4 Then setup a delay profile
If this does not work for you try deleting all the SHM modules and start over
Here is what I have - did I do it correctly? I did smart app - not Device handler. I look on my phone and I do not see the app.
Looks correct
In the SmartThings phone app click automation
Tap smart apps
Scroll down tap add a smart app
Scroll down tap my apps
Scroll Down tap SHM Delay
You may be on the wrong Shard / server
Click Location before installing anything
That was it!!! I must have been in the wrong location! It does not chime as a warning but it does arm and disarm the alarm. Success!!! Thank you very much!!!
If if it Chimes on the away exit delay make sure you specified it in the delay profile. If it does not chime on the exit delay press and hold the 2 key to try and raise the volume.
